TS-112 PAGINA WEB ATTIVA SENZA ICONE
LUCIANO-MANZOCCHI
BUON GIORNO A TUTTI SE QUALCUNO MI PUO' AIUTARE CON IL MIO TS112...L' ALTRO GIORNO NEL TENTARE DI ENTRARE NEL NAS PER AGGIUNGERE UNA CARTELLA MI SONO ACCORTO CHE RIESCO AD ENTRARE MA TUTTE LE ICONE PER ACCEDERE AI SERVIZI DEL NAS SONO SPARITE. NON POTENDO PIU' ACCEDERE HO DECISO DI FARE UN RESET DEL SITEMA SENZA ALCUN RISULTATO.LA COSA STRANA E' CHE IL DISCO ERA UTILIZZABILE DAI PC INFATTI SALVAVO E SPOSTAVO LE CARTELLE SENZA PROBLEMI...OVIAMENTE ADESSO NON HO PIU' NIENTE PERCHE' CON LA PROCEDURA DI RIPRISTINO HA FORMATTATO ANCHE IL DISCO.LA PROCEDURA DI RESET CHE HO FATTO E' QUELLA "INVASIVA" TOGLIENDO IL DISCO E TENENDO PREMUTO RESET POSTERIORE E TASTO DI ACCENSIONE FINO A SENTIRE I BIP E COMBIO STATO DEI LED DI SEGNALAZIONE SUL FRONTALE.POI RIMESSO HD, RIAVVIATO , MA NULLA DA FARE SEMPRE IL PROBLEMA DEL WEB SERVER..QUALCUNO MI SA DIRE SE E' POSSIBILE RIPRISTINARE IL FIRMWARE SENZA AVERE ACCESSO DAL WEB SERVER MAGARI DA DOS O CON QUALCHE PROGRAMMINO...GRAZIE A TUTTI DEL VOSTRO AIUTO.
