Collegamento SSH rifiutato
ratman
Messaggio da ratman »
Salve a tutti,
ho un T219P, e mi collego tramite ssh senza problemi. Da qualche tempo, ogni tanto non riesco a collegarmi per questo motivo:
Codice: Seleziona tutto
@    WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!     @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that the RSA host key has just been changed.
The fingerprint for the RSA key sent by the remote host is
6a:12:17:c1:e0:76:4c:9e:71:a8:ff:44:0d:70:d9:9d.
Please contact your system administrator.
Add correct host key in /home/ratman/.ssh/known_hosts to get rid of this message.
Offending key in /home/ratman/.ssh/known_hosts:2
RSA host key for balena has changed and you have requested strict checking.
Host key verification failed.
Rimuovo la fingerprint dal file known_hosts, mi riconnetto e ottengo:
The authenticity of host 'balena (192.168.1.34)' can't be established.
RSA key fingerprint is 6a:12:17:c1:e0:76:4c:9e:71:a8:ff:44:0d:70:d9:9d.
Are you sure you want to continue connecting (yes/no)?
Confermo con 'yes' e sono a posto. Ma dopo qualche tempo il problema si ripresenta. Inoltre, la fingerprint RSA è sempre la stessa! Non è cambiata, come dice il messaggio di errore.
Qualcuno ha lo stesso comportamento?!
