QTS 5.2
QTS 5.2
Buongiorno, è uscita la Beta Pubblica del QTS 5.2, precisamente la QTS 5.2.0.2737 build 20240417 Public Beta.
Ho un TS 251 ed un 451+ su cui provarla......
[Important Notes]
- Due to compatibility issues, please update your QVR Face Insight, QVR Face Link, or QVR Face Tiger to version 1.7.1 or later before updating QTS to version 5.2.0.
[New Features]
App Center
- Users can now select what apps to install by browsing the list of installed apps on any devices connected to their QNAP IDs. To access this feature, go the the App Center, click the "Install" icon in the top-right corner, and then select "Apps Installed on All Devices".
Control Panel
- Added a setting on certain device models for enabling disk auto recovery, which automatically reconnects any disks that have been unintentionally disconnected from the system. The setting can be found in Control Panel > System > Hardware > General.
File Station
- File Station now supports the multimedia file formats WebM and WebP.
- Detailed event logs and access logs related to share links are now available.
- In File Station, thumbnail display is now available and configurable for Microsoft Office and EML files.
Network & Virtual Switch
- Users can now configure 802.1X authentication for greater network security.
SAMBA
- Added a shared folder setting which allows the system to immediately synchronize data to disks when requested by SMB clients, thereby enhancing data integrity. You can enable the setting on a shared folder by editing its properties in Control Panel > Privilege > Shared Folders > Shared Folder.
- Microsoft Networking (SMB) service is now a standalone application called SMB Service, which can be updated independently. SMB Service enables remote access to your QNAP device files and folders via the Microsoft Networking (SMB) and Common Internet File System (CIFS) protocols. To enable SMB Service, you must enable Microsoft Networking in Control Panel.
Snapshot& Snapshots
- You can now calculate the size of snapshots in a volume or LUN that were taken within a specified time period. This feature can help you determine how much space you can free up by deleting a certain number of snapshots. To use this feature, open the "Snapshot Manager" window of a volume or LUN, and then click "Calculate Size".
- Added support for TCG Ruby SEDs.
[Enhancement]
Control Panel
- Administrators can now disable 2-step verification for a user in Control Panel > System > Security > 2-Step Verification.
- To enhance device security, when you initiate restoring a device to factory default in Control Panel, you are now prompted to create a new administrator account or to retain the currently logged-in administrator account, and the default administrator account "admin" will be disabled.
Desktop & Login
- Administrators can now choose to skip a firmware update when the firmware update notification appears upon desktop login.
- Optimized the desktop loading speed.
- To increase device security, after restoring a device to factory default using the hardware reset button, and then logging in with the default administrator account "admin", you are now prompted to create a new administrator account and to disable the "admin" account.
- Added support for copying and pasting security code (TOTP) credentials when configuring 2-step verification.
- If you access your NAS primarily through a single AD domain only, you can now conveniently log in to the desktop without including the domain name in front of your username. For example, you can now enter "myusername" instead of "mydomain\myusername". (Note: However, if you use multiple AD domains or use both local and domain user accounts to access your NAS, you should still specify the domain name when logging in with a domain user account.)
iSCSI&FC
- You can now edit an iSCSI target's IQN during or after target creation (maximum 128 characters). To edit an existing target's IQN, you must first disconnect all connections to the target, and then go to iSCSI & Fibre Channel > iSCSI Storage, select the target, and click Action > Modify.
- Users can now copy all network information (including IPv4, IPv6, and hardware) of any physical adapter or virtual switch to the clipboard with a single button. Open Network & Virtual Switch, go to "Network" > "Interfaces" or "Virtual Switch", identify an interface, click "More" > "Information", and then click "Copy".
Resource Monitor
- Improved the calculation method and display of system memory information in Resource Monitor for greater clarity.
- Enhanced the Network Connectivity Status Indicator (NCSI) service, which periodically checks the network connection status. You can now enable this setting and configure its checking target no matter whether you choose automatic or manual selection of the system default gateway. To configure NCSI, go to Network & Virtual Switch > Network > Interfaces > Interfaces, and then click System Default Gateway.
Storage & Snapshots
- In the Volume Creation Wizard, the setting "Enable snapshot schedule and snapshot retention" is now disabled by default. This ensures that users who do not need snapshots will not unexpectedly encounter insufficient storage space caused by a large number of volume snapshots.
- Improved the synchronization process for read-only SSD cache to optimize data read efficiency and reliability.
- Optimized the RAID group resync speed for NVMe drives.
- Users can now view detailed temperature information about their Seagate EXOS JBOD enclosures in Storage & Snapshots > Storage > Disks/VJBOD > NAS and Enclosure.
Surveillance
- Added support for the newly upgraded QUSBCam (version 3.0.0, previous version known as QUSBCam2).
[Other Changes]
Control Panel
- The ClamAV antivirus engine is now an independent application, allowing the Antivirus service to consume less memory and spend less time scanning files. Note that in order to use Antivirus, ClamAV must be installed in App Center.
- The system now checks whether a new QNAP Software Terms of Use is available before performing a firmware update. Administrators must agree to the new terms to proceed with the firmware update.
SAMBA
- Implemented direct I/O in the kernel-mode SMB daemon to enhance read and write performance.
System
- Improved the speed of starting and stopping applications during system startup, shutdown, and restart.
[Known Issues]
- Due to compatibility issues, QNAP NetBak Replicator is currently unable to establish an SFTP connection to a NAS running QTS 5.2.0.
Re: QTS 5.2
Sul TS 251 ed sul 451+ non ho notato problemi di sorta.
lucam1970
Re: QTS 5.2
Messaggio da lucam1970 »
grazie dell’info @PiaNi.
Io però prefersco aspettare che esca dallo stato di beta…
Re: QTS 5.2
Come ho scritto, ho due qnap a non fare quasi nulla, e posso provare queste cose.
Interesssanti le novità, SMB adesso è un servizio, il backup della configurazione salva molte più informazioni e può essere utilizzato anche per cambiare qnap. Velocizzato l'avvio e lo spegnimento del 30%, chissa se arriveranno ai circa 60 secondi di un Synlogy!
https://www.qnap.com/qts/5.2.0/it-it/
Re: QTS 5.2
PiaNi ha scritto: 01/05/2024, 13:01 Come ho scritto, ho due qnap a non fare quasi nulla, e posso provare queste cose.
Lo stò provando adesso ma purtroppo la velocità del synology c'e la scordiamo, non c'e paragone
Navigare nei vari menù è di una lentezza disarmante se paragonato a synology, ed è un peccato
Nonostante il mio abbia 16 gb di memoria
Re: QTS 5.2
New release: QTS 5.2.0.2782 build 20240601 Release Candidate
lucam1970
Re: QTS 5.2
E' disponibile la Release Candidate 2
QTS 5.2.0.2802 build 20240620
[Security Updates]
- Applied multiple security updates to further enhance system security.
[Fixed Issues]
- Fixed an issue where logging in to QTS would take a long time under certain circumstances.
malex
Re: QTS 5.2
Messaggio da malex »
Volevo riprovare l’interfaccia ma sono giorni che la demo è in manutenzione
zinzi
Re: QTS 5.2
Messaggio da zinzi »
mi "attacco" a questo post, anche se con un po di ritardo, in quanto con la mia TS-231P con QTS 5.2 sto avendo problemi ad installare WordPress.
Praticamente è una cosa che ho già fatto con successo prima della 5.2 e senza alcun problema, ma ora vedo che le cose sono cambiate (compresa la cosa della Conteiner Station, che sto iniziando a capire cos'è ma non perchè sia stata implementata : Eeek : : Eeek : ) ma la cosa principale è che WP non parte correttamente. Cioè mi spiego meglio: tutte le installazioni vanno a buon fine (Mariadb 10, myphpAdmin, e WP) creo il db su MARIA ma poi quando lancio WP, mi indirizza su una porta mai vista (la 51666) dove non vi trova nulla...ho cercato un po in rete, ma gli articoli sul sito QNAP in relazione a Wp risalgono al 2022...inoltre me ne sono andato anche per un'idea di installare tutto nel container, (phpadmin, maria e wp) ma anche se li WP parte bene, invece ho avuto problemi con MARIADB che non mi fa loggare con root/admin...inzommma....come me ne esco??
Grazie a tutti in anticipo : Chessygrin :
lucam1970
Re: QTS 5.2
zinzi ha scritto: 07/07/2024, 20:13 Ciao a tutti,
mi "attacco" a questo post, anche se con un po di ritardo, in quanto con la mia TS-231P con QTS 5.2 sto avendo problemi ad installare WordPress...
ti consiglio di aprire un thread dedicato al tuo problema.
Se ritieni di farlo, sii un po' più specifico.
Che tipo di installazione stai tentando di eseguire per Wordpress, MariaDB, etc,etc ?
Da AppCenter? Oppure citi Container Station perchè vuoi installare tutte queste app con docker?
Prova a fornire più dettagli che puoi. Alla fine ti può aiutare solo chi è passato in una situazione simile alla tua oppure chi ha una solida preparazione.
zinzi
Re: QTS 5.2
Ok grazie lo farò
lucam1970
Re: QTS 5.2
Nuova RC3 datata 18 luglio
QTS 5.2.0.2823 build 20240711 Release Candidate 3
[Security Updates]
[Fixed Issues]
Re: QTS 5.2
Poca roba, vuol dire che fra un po' esce la beta.
lucam1970
Re: QTS 5.2
Chiedo scusa, per un mio errore nel copia/incolla, il post con le caratteristiche del nuovo firmware era incompleto.
Di seguito il testo completo:
[Security Updates]
[Fixed Issues]
- Fixed an issue on the TS-h1887XU-RP where the NAS might repeatedly restart on its own after updating an expansion card's firmware.
- Resolved an issue where the system might not be able to detect a network interface card (NIC) after updating the card's firmware.
- Fixed an issue where users could not access a shared folder in File Station if the shared folder was linked to another folder, even though they had access permissions to the shared folder.
Effettivamente dovremmo essere vicini alla beta ....
lucam1970
Re: QTS 5.2
... e invece no ... Release Candidate 4 ...
QTS 5.2.0.2851 build 20240808
[Security Updates]
[Enhancement]
Control Panel
- Added support for HTTP Strict Transport Security (HSTS), which enhances connection security by forcing a client browser to connect to your server through HTTPS only. You can enable this setting on the NAS server in Control Panel > General Settings > System Administration, and on the web server in Control Panel > Applications > Web Server.
[Fixed Issues]
- Resolved an issue in File Station where after navigating between the pages of a search result, sometimes the page number at the bottom did not correctly correspond with the files displayed on the page.
- Fixed an issue where after replacing a disk on a legacy volume, the system could not successfully rebuild the volume.
- Fixed an issue where a user's home folder (e.g., /homes/user1/) could no longer be accessed in File Station after deleting the user and the corresponding recycling folder (e.g., /homes/@Recycle/user1/).
- Resolved an issue in File Station where a search might return incorrect results if the search keyword included certain special characters.
- Fixed an issue in File Station where users could not move a file extracted from a zip file (even though they could do so via SMB).
- Improved the application stability after a system restart.
- Resolved an issue in File Station where under certain conditions, a folder's properties window would display an incorrect folder size after clicking "Calculate Size".
- Fixed an issue in File Station where under certain conditions a user could not delete and move a file to the recycle bin from a search result.
- Fixed an issue where non-administrator users could not search NAS file contents via SMB on macOS.
- Resolved an issue where under certain circumstances some users could not access a folder in File Station even though they had the permissions and could access the folder via a network protocol.
Re: QTS 5.2
Prima avevamo le beta camuffate come normali rilasci, e adesso quattro RC prima di una versione normale!!
Vincenzov
Re: QTS 5.2
Messaggio da Vincenzov »
ciao a tutti, io ho ultima beta del 8 agosto, ho notato che quando cancello un file dal nas (tramite nfs linux), mi dice che non puo' metterlo nel cestino ma lo elimina direttamente, invece se sono nel file manager del qnap lo mette tranquillamente nel cestino.
Re: QTS 5.2
C'è la versione 5.2.0.2851 build 20240808.
Non è altro che la RC 4!! : Chessygrin :
lucam1970
Re: QTS 5.2
Aspetterei ad aggiornare.
Sul forum in lingua inglese segnalano un problema.
La pagina è questa: https://forum.qnap.com/viewtopic.php?t=175035
Il titolo del thread è stato aggiornato evidenziando che il problema sarebbe originato dallo 'Storage Widget' e che sarebbe stato risolto.
Non ho ben capito di cosa si tratta. Non avevo mai sentito parlare di widget per QTS.
Forse è una nuova funzione di questa nuova serie 5.2.x del firmware.
lucam1970
Re: QTS 5.2
... e, infatti, a distanza di pochi giorni nuova release....
QTS 5.2.0.2860 build 20240817
Sembra che abbiano messo mano a un sacco di cose....
[Important Notes]
- After updating QTS to 5.2.0, important updates are required for certain apps due to OpenSSL updates, such as Malware Remover and Multimedia Console. To ensure their functionality, you can go to the App Center and manually update these apps to their latest versions. (All applications dependent on Multimedia Console will also resume their normal functionality after Multimedia Console updates.)
[New Features]
App Center
Control Panel
File Station
SAMBA
- Added a shared folder setting which optimizes data synchronization to disks from SMB clients, thereby enhancing data integrity. You can enable the setting on a shared folder by editing its properties in Control Panel > Privilege > Shared Folders > Shared Folder, and selecting "Instant sync to disks when requested by SMB clients".
Storage & Snapshots
[Enhancement]
Control Panel
- The system backup and restore functions have been upgraded with new capabilities and options. You can now restore system settings to a device of a different model running the same or a later firmware version, configure specific settings you want to restore (including general, user/group, shared folder, and network settings), install or update the applications recorded in a backup, and set up an automatic backup schedule.
Desktop & Login
iSCSI&FC
OpenSSL
- We have updated OpenSSL to version 3.0 for improved cryptographic performance, enhanced memory protection, and simplified integration with modernized APIs. Users can now experience optimized system responsiveness and better data protection.
Resource Monitor
Storage & Snapshots
Surveillance
- When users try to enable encryption on a shared folder, the system now checks and alerts users if there are file names exceeding 143 characters or file paths exceeding 2048 characters.
[Other Changes]
Control Panel
- To enhance the security of your device, the default password for the system administrator account "admin" has been changed to your device's Cloud Key. For details, see this FAQ: https://www.qnap.com/go/how-to/faq/con_ ... p?cid=2288
SAMBA
- Implemented direct I/O in the kernel-mode SMB daemon. When the kernel-mode SMB daemon is enabled and all disks on the system device are NVMe SSDs, direct I/O enhances read and write performance.
- Adjusted the display rule for log records of failed SMB login attempts.
System
